Guild Wars 2
im getting 30-50fps with max settings on a 7850 but only 50% gpu usage.
i thought maybe i was cpu limited but in task manager no core is fully maxed out :S
ive noticed after zoning sometimes my fps dives to 20-25 but if i reset the settings to best "best appearance" and then manually stick shadows/LOD back to there max my fps is fine around 50 again :confused: (although still no maxed out cpu cores and still only 50% gpu usage)
I'm running a 7850 and the hour or so I managed to play this morning I was getting over 80fps with GPU at 90%. Too hot for me so tweaked down the shadows and shaders and enabled v-sync (was getting tears). Got a a nice 60fps at about 50-60% GPU load.
Finally, able to get on to the log in screen ... but won't go any further. You'd think ArenaNet would have the decency to let me back in game before you lot ;)
