Got a link to that? Sounds interesting.![]()
God that was a mission to find again
http://kerbalspaceprogram.com/forum...Engineer-Redux-Version-0-1?highlight=engineer
fuel tanks need to be in same stage as engine, or it wont calculate.
you can only use one part, or it doesn't work.
part must be removed before launch. otherwise rocket will be very unstable. not sure why as the part has zero drag.
it cant calculate complicated setups. like out fuel tanks with engines that drain into a center one, then discarding outer ring. but still gives you some idea.
 Not the best of crafts. I'm about to set off and fly it around the mun.
 Its a little wonder it rips itself apart.
