£1200 Gaming Spec (First PC Build)
Asks me to sign in, if you want email me the picture by clicking my trust button on my post and I can upload your image and post (click send message)
Edit: You might need to send a message first then I can reply and then you can send me the pic.
Thank you!
So, a small right angled sata data port *just* clears the blades but the large sata power connector (not right angle) does not clear.
If only the power connector could be right angled - is there such a thing as an adapter?
What I my options now everyone has had a look?
Thank you again everyone
Looking at the pic in a little more detail now, is there a possibility of using one of the other SATA power connectors and have the other one clipped out of harms way.
Edit:
I've just been trying, it could have worked but the other sata power cables seem to be 'up side down' in terms of the little notch that creates an L shape. :(
Apologies leta me rephrase: the front of the case will not fit two 120mm fans without the removal of the optical drive tray.
Lol, okey dokes... :D It's not hugely necessary tbh, it's just a bit more optimal if you're not running a front fan on the cooler (I still reckon it could be ziptied though).
If it was my case, I'd either run an external optical drive OR run a rear fan on the cooler and cut out the rear exhaust grill. Obviously, I wouldn't expect F4ust to do that though.
My advice, try it with a rear fan and see how it goes. You'll lose maybe 1-3C worth of cooling which isn't much at all :)
I have managed to use the following cable to connect to the back of the optical drive.
PSU====]====]====8====C
The connection is made on the 2nd sata power connector in the row ( ] ). The cord loops over the fan and the 3rd and 4th connectors dangle unused although they have ports that I don't seem to need. The first sata goes to waste pushing against the ceiling of the case.
I have sent another photo but suffices to say there's at best ~3mm clearance.
I don't know how I feel about this - what sort of 'pc builder's philosophy' should i adopt. Should I be a pragmatist and say to myself: "if this solves it then no harm no foul - carry on" or should I be looking to solve the situation in a 'safer' or less of a 'bodge' way?
When we build we sometime have to make changes which solve certain issues. If works then leave it, I lost count how many times I have removed and changed cables around whilst building.
Hi can you post about any other problems (solutions) there have been during your build? I'll be starting my own build of a very similar system soon. A few photos would be appreciated. :) Cheers
