*** ArmA II Thread - OA, CO, PMC, BAF ***
You offshore now mate?
Guys
A little known application that uses the six.rsync network.
http://www.armarize.com/
A new version just released which fixes the game spy problem, does the exact same job as six updater, never tried it yet, might be easier to use..
If someone does use it, can they update and let us know how it is.
Thanks
Guys
Thanks
Hi MarkeR,
I'd like to play on your server, however I run quite a few addons which you do not have the .bikey files on your server for. Would you be willing to allow for more addons? Here's a quick list of some addons that I use (which I don't think are allowed), no worries if you don't want to allow them. It's your server. :)
@AllRoundDefence - Unsure how it reacts to MP.
@BlastcoreVisuals
@GDTMod-NVG
@GDTMod-Sun
@IVD
@JSRS
@JSRS-ACE
@LEA (LoadoutEditor)
@SMK-Animations
@ST-MapAutoBrightness
@ST-HUD
@ST-LBEnhance
@ST-Movement
@TrueUser
should be on from around midnight tonight work permitting and have the next two days free......wanna get my head around ACE as there seems to be a lot of different features with inventory etc.
Any of the more experienced players know of the most obvious tips before I have to trawl through ARMAHOLIC forums.
Thinks like the balaclava, earplugs and HUNTIR and stuff like that is all a mystery :confused:
Ok I'll restart it just now mate
Missile, obviously you know you can disable the mods in your start up line, or whatever launcher you use!
If you use six launcher or amarize, you can create shortcuts and presets to launch the game when you sync the mods used with whatever server you want to join..
I don't want to add too much right now. As I want to keep it as simple asossible..
The rws sound mod I feel is better than jsrs. STHUD will be going on tonight.
I'll have a look at blast core visuals.. The little bird enhance one, I have seen before. Looks awesome to be honest... We can add a list of the mods we all want and then add them onto the server, more than anything I want everyone from here to be hopefully able to join with no problems.
Cheers
Sorry mate..
The remote gaming panel is down for maintenance. If an adminis around can you login via rcon or in game and restart please.
Thanks
Cheers
Hello,
Thanks for the quick response. Are you using SixUpdater to manage the server? I'm unsure exactly how that system works for servers since I managed mine manually, but I would assume that it downloads the entire addon and places the .bikey into the 'Keys' folder. To allow people to run a certain addon if you have signatures enabled, you only need to place the .bikey file that corresponds to the clients' addon .bisign file into the 'Keys' folder.
I you like I could quickly upload the .bikey files for some addons that you don't have on the server, for you to choose from.
If you're downloading client-side only addons to the server, then that's not needed and is just wasting space. Please don't take this the wrong way if you already know all of this, I don't know you. :)
Edit: I must apologise for bugging you, I'm obsessed with addons. At my peak, around three years ago I had nearly three hundred. Lost them due to a virus though. :(
I'll upload the bikey files no problem mate..
Just send me what you require, absolutely no problem. As you would know, trying to make it as easy as I. An for people to join..
Feel free to also join the ts3 server, it's all over the dayz thread, at work and cannot remember the ip etc..
Updating the server manually mate, but I am recommending that people use six or armarize to keep synced with it... Just makes it easier..
Anything new we need for tonight dude?
Is there a way of turning up ACRE volume above the limit on the radio itself? Especially in vehicles I can't hear a thing anyone says, I've played around with the audio options in-game but it didn't change much. That harbour mission seems cool, I'm +1 so always gets a bit late by the time we get going though!
Is the server up and running? I can see it in the list and it says "Creating" but if I click to join I get stuck where it says "Wait for host".
Any ideas? Oh, I've started using Play withSix as per this thread.
Cheers.......Mad Jock
Jock
Get the updater to synch the mods with the server preset!
Make sure dayz isnt enabled, come onto TS3 and we can sort it for you!
As above HR4.
Shack_Tacs single key is used for all of them except st_lb_enhance!, SO already enabled!
NIce little instructions on how to use six updater!
Graphics are different, but same principle!
http://wiki.rustyinplaces.org/article/SIX_Updater#Add_server_presets
