is the update today for this as its the 5th??
Yep, yep - £30 sat on PSN account, ready for cheap subs....
is undead nightmare worth it? I.ve read its meant to be ok and told that its not worth it as it just doesn't compare to red dead
quick question re plus folks, when i first subscribed to Plus a couple of years ago, I remember that it used to download demos and plus content overnight, along with uploading my saves etc.
anyway since re-subscribing a couple of months back, i still have my savegames uploaded overnight, and it occasionally downloads patches, but ive yet to see any content being downloaded (ie plus games or demo's).
have i turned off a setting somewhere or is this normal now?
cheers
It's normal, mine has only ever auto downloaded 1 demo since they started it, it's never auto downloaded the plus games.
yes and no.In all honesty, is it worth a buy?
Very quick question and apologies as it's likely been covered but any games downloaded for free as a subscriber, can you keep if you cancel?
Is a PS+ sub worth getting for a Vita alone? I did have a PS3 (well I still do) but it's afflicted with that horrible YLOD, which I haven't been able to fix using the heat gun method.
I might pick up a cheap second hand PS3 at some point, but it's just a Vita for now.
no, the games are yours for the length of your sub. when your sub expires, you are unable to access anything you had acquired in the sub period.
However (and something i recently found out for myself), If you take out a new subscription in the future you are then able to re-download the content you had previously acquired as part of your original subscription.
Sometimes the games should auto renew the licence. Some you can start them then quit etc and the licence will renew. But for ones that dont start the download then cancel it, it should renew
