What's your reasoning for that? Was thinking of getting the PE over the Gigabyte, windforce x2 looks poop.Get the Gigabyte 7850, can you afford a more expensive PSU that is quieter? You also wont need the SATA cable.
The motherboard will come with sata cables.I do need it i got 1tb without the cable and whats wrong the msi? and any psu ideas?
Windforce is quieter, high levels of overclock, has UK RMA if something goes wrong, and currently is good pricing.
The motherboard comes with 4 SATA cables.
MSI is UK RMA to. I think the windforce is quieter but OC'ing is luck of the draw, I've read reviews of the Gigabyte 7850 and it states the OC headroom was poor with them but it's all just luck with what you get I guess.Windforce is quieter, high levels of overclock, has UK RMA if something goes wrong, and currently is good pricing.
The motherboard will come with sata cables.![]()
Not very good, you might as well keep the OCZ.
Not too bad looking at the review below:
http://www.anandtech.com/show/4908/silverstone-strider-plus-500w-modular-power/5
