Do you have a bar and a rack?
Got a olympic bar but no rack.
You don't need a belt for anything. Seriously. You do need to make sure your back is straight, but a belt won't help with that.Got a olympic bar but no rack.
Single leg db romanian deadlift, looks difficult. Plus the others look like womens exercises lol
Goblet squats look good, do i need a belt for that?
Ill give it a go, not something id do in the gym though once i join or ill be called gay
So ive got
Goblet squats
DB leg workout:
Reverse lunges
Step ups
3 x 10 of what ever weight im comfortable doing a maximum of 10 reps?
If you find you're completing the 3 sets without issue, then the weight is nowhere near high enough.
And get a tutorial at the gym when i join.Cheers, i guess this first leg session will be bar setter for the amount of weight i need.
You know how it is though, you want to be doing the manly things everyone else is doing, like squatting. I might just do some without any weightAnd get a tutorial at the gym when i join.
Are dead lifts not for legs? and i forgot ive also got the thing that attaches to the front end of the bench so you can do "leg raises"?
Yeah, I mean look how gay this is:
The guy who won his weight class at the British Classic Powerlifting Championships does these with DBs in the appropriate training block.
Just do them, they will light up your hamstrings. Otherwise you are kind of neglecting them with the rest of what you're doing.
I think ill just incorparate what i feel capable of doing, theres no rush.
A couple of quick questions.
Is it best to do cardio before or after weights? Im trying to do treadmil everyday to improve cardio and lose weight.
And is it best to have a seperate day for arms or do biceps when doing back and do triceps along side chest day?
but dam do they do some damage!
, cant imagine what ill be like once im doing it all properly!
Goblet squats are less hip dominant, but will give your core stability a good test, too.Congratulations on a proper workout.
YEs, the front leg is supposed to hurt with reverse lunges.Goblet squats are less hip dominant, but will give your core stability a good test, too.
Lower back pain from step ups is probably an artifact of weak core muscles and lack of glute engagement. More planks and hip mobility work, methinks.
Deadlifts are a bar steward exercise: if you think of all the muscles you're activating, you'lll get an idea for why you get breathless. As an example, anyway.
Good work - keep it up!
Glad you left out one legged deadlifts, reckon someone was having a laugh with that.
i'd echo this, well done fella.
If it came easy we'd all be uber fit adonis's.
I'm struggling right now too, but i'm content that i know enough to get into the shape i want to be in.....motivation however, well that's a different kettle of fish!
You need core stability first (especially if you're a little overweight), and as mrthingyx said, plank, even goblet squats (which will open your hips out for better 'proper' squats) will help develop your core well.
Your lower back pain from step-ups may be as mrthingyx said, but also from poor technique. Are you sure that when you're struggling your technique isn't faltering too much resulting in you flat-footing on the ground and impacting on your lower spine?
With the general weightless squats, deads and luinges, i'd be tempted to just do weightless step-ups as purely a stamina exercise, quickly and lightly touching your feet on the step and back down again without the deliberate and slower 'stamping' of the foot down when holding weights.
just a though.
I agree with you, but I said it because its still a pretty advanced technique to try when the op is clearly inexperienced and generally unfit.
Why would that have been a joke? It wasn't, they are an excellent fundamental exercise. If you can't do them, you have strength and balance deficits that need addressing. How? By doing them.
