Carl Ewans
Welcome to eBay Live Help, my name is Carl. How may I be of assistance?
tomas
Hi, my buyer wants to return a working item because they do not know how to use it. I am not a business seller and it was a private sale on a buy it now, so do I have to accept this back?
Carl Ewans
I do understand your situation on this. Aside from your buyer that wants to return the item,is there anything else you would like me to look into for you?
tomas
No that is all, I just don't think I should be having to accept things back because he can not use them?
Carl Ewans
I will just need a moment while I check this for you. Please stay connected Tomas.
Carl Ewans
Thank you for patiently waiting. Since the buyer already filed a Return case, all you have to do is accept it. Once you already do this, the buyer will be oblige to post the item to you again, with that, it is your option if you wantt o replace or refund the payment of the buyer.
tomas
The item works, he has told me that. I do not see why I should accept the return.
Carl Ewans
Alright. If that is the case, you will have the option to reject the Return case. The process goes like this, once you reject the Return case, the buyer will file a Not as describe case, on they have do that, all you ned to do is respond to the said case with a helpful information so when our Resolution team investigate on this there will be a possibility that the case will be close on your favor.
tomas
I think its a small possibility and I will just end up having to accept it back, don't you?
tomas
How about if I accept the return case and then get the item back and it works? I'll still have to refund him won't I?
Carl Ewans
In this case, there will be a possibility that there is no need for you to refund them. It is your descretion, since you are confident the the item is not working there is no required action for you to do so.
tomas
ok, and what if the buyer then does not want it back?
Carl Ewans
On that case you are not required to refund or accept the case.
Carl Ewans
Sorry for the delayed response as I am having a Technical difficulties.
tomas
but like you say, he'll just open a case and probably win, so i am just going to lose out whatever happens
Carl Ewans
In this case, seller most likely wins as we belive that there is no seller will post an item that is not working.
tomas
Ok thank you
Carl Ewans
Welcome, it is my pleasure to assist you. Thank you for contacting eBay Live help. Goodbye and take care.
