New keyboard and mouse
11 Oct 2007
London, UK
Hello,
After attending i46 and getting to try out the CM Storm line of keyboards, and the corsair M60 mouse, I have decided that its worth upgrading to a mechy keyboard and a new mouse. After perusing the range here on ocuk, I think I have decide on the below two products.
http://www.overclockers.co.uk/showproduct.php?prodid=KB-002-CS&groupid=702&catid=23&subcat=1258
http://www.overclockers.co.uk/showproduct.php?prodid=KB-001-CS&groupid=702&catid=23&subcat=1257
At home I currently use a G19 and G500 on the main PC, and G15 rev 2 and G500 on the living room PC. At work I use some random dell keyboard and a CM Storm Inferno mouse.
So, you can tell I like the right handed ergonomic mouse, as thats what I am used to.
Reviews of both products seem to be good, but I am wondering if anyone has any personal opinions on them, if they have tried them and similar products? Or if there is something better/equally as good for similar monies?
i have the m60 and love it :) so i imagine the m90 is the same feel but with more buttons. and i like the feel of the k90 but not all of the keys are mechanical. i use the q-pad mk50.
I have both the k60 and m60.
Have no complaints, and they both feel comfortable.
With regards to the mouse, try it before you make a purchase, as it's ergonomic-ness might vary depending on whether you prefer a claw or palm grip.
Ergonomic is preferred. The shape of the m60 i tested quickly at a lan was fine :)
The Qpad MK-85, looks good, but I cant see the macro keys on it, even though it mentions them in the description?
If its anything like my saitek cyborg you can bind functions to any of the keys you want, eg bind actions to the function keys for mmo games.
I'm looking at the CM Quickfire Rapid too. It's very highly rated.
I use a 3M ergonomic mouse. Ergonomic here has a different meaning compared to the M60 ;-)
Not sure if you have seen this OP, but the two you have chosen come as a package. :)
http://www.overclockers.co.uk/showproduct.php?prodid=BU-018-CS
Cheers, I had not noticed that :)
I tried out the CM range of keyboards, although they had blue switches not red, and its what made me decide to buy a new keyboard tbh. but I want a nice volume thing, and "g keys", even though I practically never use either anymore. I SHOULD use them, could put so many commands in autocad on them :)
Thanks for the advice guys, Looks like they are all considered "good" so I should just get whichever one looks best to me :)
