- 5 Jan 2010
- London
ANSWERED AND ORDERED
See here for more info behind me going for the GTX660ti by MSI:
http://forums.overclockers.co.uk/showpost.php?p=22814469&postcount=32
I'm a little lost as to which to go for - both sit in my price range. For the research I have done it is really hard to pin down.
660 GTX ti vs 660 GTX ti SC+ vs 660 GTX ti PE vs 7950 vs 7950 OC
Basically, this is what I understand from all the searching I've done:
It's all about your personal preference.
There are certain games that the 660 gtx ti does better in, and others the 7950.
The thing is this, at stock:
7950 has lower clocks, higher mem and bus
660 has higher clocks, lower mem and bus
660 is favoured atm for people who game, as it supports games much better. ie. BF3 is designed for nvidia.
Now for overall, long-run, it seems the 7950 is better because of it's high bus and mem size - this will allow it to stretch to high limits in the long run.
However it should be noted that both are OC'able - now I don't want to OC, but if you want to OC the GPU's the 7950, can out-perform it's bigger brother the 7970 (stock) - so for me, I'm leaning for the MSI AMD Radeon HD 7950 TWIN FROZR.
Ref:
MSI HD7950:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-148-MS
EVGA GTX660ti SC:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-198-EA
MSI GTX660ti PE:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-172-MS
Could anyone point me in the right direction?
I should note that I would want something that can be a little on the quiet side
Also warranties are something that's important to me - so how would each cope internationally speaking? If I moved let's say from the UK - how would I deal with it? Will MSI for example deal with that, in another country?
Any help would be appreciated
Ref:
MSI HD7950:
EVGA GTX660ti SC:
MSI GTX660ti PE:
