23 Sep 2012 at 16:32 #1 T345 T345 Soldato Joined 14 Oct 2011 Posts 5,740 Location Kent Best ITX case for around £80and under? NO Bitfenix ITX as it is quite big,
23 Sep 2012 at 16:41 #2 Idleman Idleman Soldato Joined 14 Apr 2011 Posts 12,269 Location Newark http://forums.overclockers.co.uk/showthread.php?t=18444045 A couple of bargains in here. Prodigy and Lian Li.
23 Sep 2012 at 16:47 #3 T345 T345 Soldato OP Joined 14 Oct 2011 Posts 5,740 Location Kent Thanks, I like this one http://www.overclockers.co.uk/showproduct.php?prodid=BG-031-LL
23 Sep 2012 at 16:50 #4 Doomedspeed Doomedspeed Soldato Joined 13 Oct 2011 Posts 11,880 Location Melbourne, Australia T345 said: Thanks, I like this one http://www.overclockers.co.uk/showproduct.php?prodid=BG-031-LL Click to expand... Was just about to come post that here, damn.. I know it's over budget but the sugo's are good and come with built in PSUs. My choice would be this:http://www.overclockers.co.uk/showproduct.php?prodid=BG-020-SV If you could afford too. The case you've picked looks really good though.
23 Sep 2012 at 16:54 #5 T345 T345 Soldato OP Joined 14 Oct 2011 Posts 5,740 Location Kent Yeah, I am planning to sell my mobo and case, then buy a new mobo and case, ITX
23 Sep 2012 at 16:54 #6 beejjacobs beejjacobs Soldato Joined 10 Aug 2010 Posts 5,508 Location Somerset If you don't mind a slim optical drive and a short ish GPU then these are great IMO: http://www.overclockers.co.uk/showproduct.php?prodid=CA-151-SV&groupid=2362&catid=1092&subcat= Used to have one (my first PC), much smaller than the Prodigy too (which I have now ) As Doomedspeed mentioned they come with a PSU so consider than with pricing.
23 Sep 2012 at 16:55 #7 RJC RJC Don Joined 29 May 2005 Posts 29,090 Location Kent I'm using the Cooler Master below: http://www.overclockers.co.uk/showproduct.php?prodid=CA-298-CM&groupid=2362&catid=2279&subcat=
23 Sep 2012 at 17:04 #8 T345 T345 Soldato OP Joined 14 Oct 2011 Posts 5,740 Location Kent That CM is nice and cheap
23 Sep 2012 at 18:29 #9 RJC RJC Don Joined 29 May 2005 Posts 29,090 Location Kent T345 said: That CM is nice and cheap Click to expand... Its not too bad to work with either and looks good. I'm pleased with it.
23 Sep 2012 at 19:14 #10 Lunatic Dreyfus Lunatic Dreyfus Soldato Joined 9 Jan 2007 Posts 4,223 Location Returning video tapes If you go Lian Li just be prepared for a 'fiddly time' of things. Lovely cases, but they're just waiting to be scratched.
