SETI@Home News Vol. 184 28th July to 24th September 2012
18 Oct 2002
Aranyaprathet, Thailand
I know I'm not technically a new member having crunched for OCUK in the 90s, but I'm proud to be crunching SETI again after a very long time away and nearly in the top 100 after only a month.
Hope to have a 480 coming on line very soon and my 2600K back from Intel once they replace it.
Watch out those in line, I'm coming through!
26 September 2012 750,000
25 September 2012 700,000
23 September 2012 650,000
22 September 2012 600,000
20 September 2012 550,000
19 September 2012 500,000
17 September 2012 450,000
15 September 2012 400,000
13 September 2012 350,000
12 September 2012 300,000
10 September 2012 250,000
24 November 2011 1,000
24 November 2011 500
21 November 2011 200
21 November 2011 100
18 Oct 2004
Cumbria
Erm.......
I've just pressed buy on some new shiney stuff........
So, I may very well be putting a few GPU's up in members market over the weekend.
I needs to bolster my poor slacking RAC.........
:D :D :D
3 Nov 2004
London
Anyone else finding that they have trouble downloading CPU workunits? Getting some (not a lot) of GPU wu, but surprisingly quiet CPUs...
don't even know if the old rescheduler/rebrander works?
18 Oct 2002
Sutton Coldfield, Birmingham
Mine is very messed up at the moment. I set the cache of 10+10 days so I should get the maximum number of units possible and while a few systems do get enough, the majority (including my main rig) only have enough for a few hours. My laptop has probably 25 WUs ready to start which take about an hour each. My main system has about 10 units for my i5-3570k and the odd few here and there for my GPU :(
Just constant Communication deferred and Download: Pending all the time. My 670 is no where near maxed out.
Bugging me at the moment as my average credit would be so much higher if I had the WUs to crunch.
I was toying with getting a cheapo £100 quid card for the office system to improve my RAC but if it's not going to get any WU then there's no point really
18 Oct 2004
Cumbria
Work shortage is a recurring theme- but usually just a temporary one.......fingers crossed :)
I'll have a couple of cheapo GPU's ready to sell off in a day or so ;)
18 Oct 2002
Out of interest what are they? The work system is a Dell with probably a standard, generic PSU so i'd imagine has one PCIe 6 pin connector if i'm lucky ha.
Also is there anyway to set priority to certain projects? So for example if I run out of SETI work, it will switch to MilkyWay but as soon as SETI work comes in, it starts crunching those instead?
Man of Honour
30 Oct 2002
Surrey
I have my settings to:
Maintain enough tasks to keep busy for at least (max 10 days). 4 days
... and up to an additional 0.01 days
Which I was recommended to do with my GPU machines.
But nothing really helps if the servers at b0rkeley won't play ball, you just have to babysit your rigs and keep hitting "Retry All" in BoincTasks Transfer window :(
18 Oct 2002
I'll change it to those for the time being and see if that helps. I want to try and keep both my CPUs and GPU filled up rather than one or the other, which has been the case recently :(
On the other hand MilkyWay has a never ending supply of WUs!
18 Oct 2004
Cumbria
I got two GTX460's (EVGA's) - they are slightly different specs as one ia an RMA replacement direct from EVGA.
Can't be sure - but I think they require two 6 pin PCI-E connectors each (will check later).
30 Oct 2002
Land of the Prince Bishop
....Also is there anyway to set priority to certain projects? So for example if I run out of SETI work, it will switch to MilkyWay but as soon as SETI work comes in, it starts crunching those instead?
Set the backup project to 0% resource share, then it will only download a wu when the primary project has no work. I have seen it work in the simple case of 1 primary and 1 backup project, but the universe will probably implode if you try it with more projects.:p
18 Oct 2004
Cumbria
Didn't hear the postie knock when this got dropped off:
cpartcert1.php
