Skoda
OP
19 Oct 2002
Jupiter
Tonight's work was fitting this...
Found £1 under the centre console, £64 now :)
Came from an Octavia so the rear cup holder still works...
And all done...
I thought £65 delivered was quite reasonable considering Golf Leather arm rests are £70+ on eBay and you would need to buy Octavia trim from the dealer...
26 Sep 2006
West Bridgford
tbh I was originally set on the blue, then this came up at the right price so I went for it. Glad I did, colour looks really good in the flesh.
It is indeed the proper engine, and the dealer made 34mpg driving it up from solihull in mixed driving so that'll suit me fine.
And it shifts quite nicely, my first turbo :)
4 Mar 2003
Chatteris
I bought my Octy vRS new in April 2011 and I went for Anthracite too. I wasn't overly keen on the blue. Black I'd owned and knew just how difficult to keep clean they were and White, although looking good was fast becomming the colour everyone wanted.
I think the grey looks stunning, especially after a good clean and polish.
Because I was buying new I added a fair few options, well with the "VAT Free" offer it seemed rude not to. So added in Heated Leather, Xenon's, Columbus Sat-Nav, Rear parking sensors, Auto Wipers, Maxidot.
Not so many of the Anthracite around, so welcome to the club :)
26 Sep 2006
West Bridgford
Good choice of options, if was buying new that's exactly what I'd add.
I've noticed I have maxidot, but I'd like Columbus nav, Bluetooth, mdi, auto lights and front parkers. I'd be interested if anyone can recommend where to get these retrofitted.
OP
19 Oct 2002
Jupiter
Experienced some trouble with my gears today, totally my own fault though.
I've read threads and seen a video on resetting the gear linkage. Mine was a bit notchy going in to reverse so i followed the guide. When i slackened off the Grip/Bush (Bowden Cable Catch) and put the gear selector into home position, the cable and catch were at funny angles from/to eachother, i moved the catch, but in doing so, snapped off one of the three threaded fingers that grab on to the gear selector cable.
I bodged it together but its starting to let go now. Took advantage of the eBay £5 off and got them both for £10 rather than £18-£20 odd. A few have commented on a more positive gear change with new ones as the rubber bush isn't worn down, i'm tempted to fill the gaps with Tigerseal to prevent any further deterioration.
This is the bush/catch i'm talking about, basially you pull the spring back, twist and it then locks open..
20 Oct 2002
Birmingham
Hi all,
Been a while since I posted here, but this is quite a good thread for me to join!
This is my 4th vRS - TFSi of course!
Tow bar is detachable and used for my bike rack before I get any jibes!
And this was a shot with my old Leon:
This is my old Octavia (had virtually from new in 2002) and my old 2005 Fabia:
And my last Fabia, that I did a part ex with to get the Octavia:
I also had the retrim done at Seat Surgeons:
I also had the wheels refurbed - just for colour change though, as I really like the black chrome colour!
Guess you could say that I like Skoda's!
OP
19 Oct 2002
Jupiter
A couple of nice vRS' there, doll!
Bought this for mine today;
It was on eBay, I messages the guy and asked him if he would end early as he was local to me, £15 later and I collected it today. Rather chuffed as its a genuine Skoda headlight and brand new too! Why change it? Over time the cover of the existing light must have not been fitted correctly, dirt and moisture have got inside and clouded the inside of the glass/plastic up. I could have stripped the current one apart and cleaned it but for the sake of a few quid, the new one came up at the right time :)
20 Oct 2002
Birmingham
Nice
May i ask where you got those VRS alloy wheel cap badges and how easy they are to fit? ( i.e. do you need to take the wheel off)?
Quite fancy a set of those for mine :)
They were from a well known auction site!
A search for vRS wheel centres should do it.
They are stickers - I did take the wheel off to get my centre caps out when I stuck them on.
But you could do it with the wheel on. I just wanted to clean them up properly and make sure they had stuck.
20 Aug 2006
I've been on look-out for a VRS (petrol one) and I think my budget is not high enough (up to 9k)
they seem to be like hens teeth ...
loads of diesel ones - very few petrol ones
7 Dec 2011
I've always noticed this too when looking at the latest VRS, but there are petrols out there well within your budget will just be a matter of waiting for the right one.
Caporegime
20 May 2007
Surrey
I just bought one for £5700! 2006 with 63k miles tho. Great nick and well spec'd with xenons and maxidot,dual zone climate,all round elec windows e.t.c, even a personal plate with 'VRS' in it
They are fairly rare though, especially with a decent spec. There were quite a few cheap ones when i was looking but most had almost no extras (basic AC, no maxidot, 17 inch alloys e.t.c).
Anyone else think the 18 inch alloys are a must looks wise. I actually couldnt consider one with 17 inch wheels because i think it looks no where near as good! ( wheels dwarfed by the car)
20 Aug 2006
£5700 - thats a bargain Jono :)
all the ones being sold in 60 miles radius of here seem to be from those "dealers with no forecourts" places .... not spending that much money at one of those places
I guess if the diesels were smilar price - a lot of people opted for the diesel varient :(
Caporegime
20 May 2007
Surrey
Yeh, there seem to be a ton more diesels for sale. I think i read somewhere that they outsold the petrol one by a huge margin.
20 Aug 2006
it almost seems that due to their relative scarcity there isn't much difference in price vs a Golf GTI from a dealer
yet I guess new the GTI was more expensive ?
I'd settle for a well kept 1.8T - older one- but they're all galatic mileages now - and seem to have got to such a cheap price they're just being run into the ground
Caporegime
20 May 2007
Surrey
Really? I found that a MK5 Golf GTI still fetched a fair premium over a VRS.I remember looking at a 55 plate GTI (super spec though, full heated leather, xenons, pretty much every option ticked when new) with 50k miles for £9k about 6 months ago!
