No Problem
It all looks perfect on my monitor so there is nothing wrong with the feed from the GPU.
Are you using DVI or HDMI to connect to the Monitor?
Just had another crash, I'm guessing someone's going to tell me it's my power supply now. Checking Event Viewer and I'm just getting
'The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.', No BSOD this time.
What is your PSU?
Actually can you post your full system specs including any overclocks.
http://i.imgur.com/KvG0o.png
Sorry for the delay in getting back to you, just had an operation and still feeling a bit dizzy.
well f5 is an old bios 2010 in fact,first thing id do is update to latest bios which is f8a
http://www.gigabyte.com/products/product-page.aspx?pid=3305#bios
make a note of all your bios pages and settings before you update the bios as it will wipe them,take pics of each page with phone ect,you also might need to flash with @bios as qflash wont support bios's larger than 1mb untill you update the whole lot qflash inc with @bios
You lost me on bios.
You need to update the BIOS on your motherboard. Google it, and make sure to take pics of your settings as wazza suggested, so you can change anything back again that you've altered.
Do you mean use Setup from atBIOS and then use the F8A file? I've got 3 of them, an .exe a batch file and a 'X58AUD3R.F8A'. Which one of these is considered a bin file? xD Appreciate the help. Honestly.
