- 10 Jul 2006
Can anyone recommend a well build umbrella that doesn't exceed 45 cm when shut (end of handle to the top)
Up to £25.
Thanks.
Up to £25.
Thanks.
An obnoxious umbrella? Lol
Da ****?![]()
I decided to go on a quest to find the ultimate umbrella earlier this year as I had tried so many before and they had all been rubbish when faced with the cruel scottish wind. I had tried expensive fulton umbrellas... none have lasted... in the end I was buying a number of £1 poundland umbrellas that would last the walk to and from work and then be binned (it actually worked out cheaper!).
I stumbled across a dutch company called Senz that make aerodynamically shaped, wind tunnel tested umbrellas. I decided to get one of the mini compact ones so I it could be deployed as required rather than carrying a brolly around all the time. Tbh, it was one of the best umbrellas i've ever had! It cut through the wind, stood fast and I was impressed!
Then the wind noticed the brolly seemed invincible and must have concluded I was taking the p*ss, so after one week of walking into work the wind flipped round suddenly (I could have sworn in the roar I heard a "get this up ye!!" and from the back it flipped it and snapped it.
You may fair better down with the southern wind, but currently my battle with the scottish wind and rain continues - one day I will find my excalibur umbrella!
Also:
www.senzumbrellas.com
You should be able to find the compact ones for £25 odd on a certain auction site.
Bin those requirements, get yourself down to sports direct and select one od their finest (golf) manbrellas for 3 quid. Job done
