Thank you for taking the time to watch my vid and write about the areas i need to improve.
I have been watching videos to get the most out of my game (i had downloaded apollos new vi but not had the time to watch it). I have heard that it is possible to have the hatcheries all one key but i cannot work it how to select them all at once, any idea?
As for my hydra+roach army its because i seem to get pwn'd by air attacks often and it was my counter. I do realise its not optimum so i will look into getting that sorted asap.
In some of my later games last night i was much better with the tech upgrades. It does make a difference in a lot encounters.
Hotkeys i know are a serious weakness, you only have to watch the korean replays to see the pace they move around the map at. I hope it just practice.
Are zergling armies that powerful? I always go for roaches because i find my lings getting gimped. Is there a secret to ling armies or is it just a case of sheer numbers?
And what is a macro hatch? Is it just a base to pump out units?
Again thanks for all your help![]()
I'll have a look at your replay tonight. Lings can be very powerful. Always get them in every match up, say in zvp you can sandwich his ball with lings and roaches to help negate FF / take fire from immortals. In zvt you mainly pump out lings unless he's going mech. In zvz you would use them less as it transitions into roach and beyond but again run bys and some for banes to stop run bys against you.
