*** The Official FIFA 13 Thread ***
Mertens? Or his he on the left?
Or Chadli.
Both of them are LW according to Futwiz. At work with rubbish connection so can't scout properly, but it doesn't list a single Belgian RW/RM >76 ??
In 12 I think there was one IF Hazard or Mirallas that was RW, but that's all I can think of.
Another quick search, looks like next best is a silver 72 guy called De Ceulaer or 71 Jonathan Legear. Might just stick a random non-Belgian RM in there instead with decent chem, dunno.
What difference does it make to the overall team in FUT if you build a Premier League team or a spanish team?
I'm confused about everyone talking about building such and such teams and then using players from that league?
:confused:
:confused:
building a team from the same league means the chemistry is high for each player / the overall team
the higher the chemistry the better the team will play so players will make runs off the ball and pass and move better and have a better understanding with each other, i belive that if they have low chemsitry then there stats are basically reduced (bot visually) but the way they play
Ok have decided to aim for a Belgium/Netherlands hybrid. But this involves trying to get Robben. Hmm. Lots of trading/pack bingeing to do...
Could do some sort of hybrid...Fellaini, Mirallas, Lukaku, and a Prem right winger?
They are the players you play with :p.
Well duh. :p
So say you choose an italian team, you cannot use UK players at all? Or if you do will it impact the team chemistry massively?
Well duh. :p
You have links, between players. Usually it's 3/4 links per player (other than GK which has 2). The links calculate your chemistry. You really need two components to the link per player. For example:
------------Hart-----------------
--------Terry----Kompany-------
--------Xavi----Gerrard-------
You get links on the league the player is in, the team they play for and the nationality of the player. So Hart links with Terry on 2 out of the three (different team) which is the minimum you want. Hart links with Kompany on all links as he plays in the same team.
Terry links with Kompany (2 links) but doesn't link with Xavi. Gerrard links with Kompany, but doesn't link with Xavi.
So Terry and Gerrard are both likely to have 7 chem (providing the other links are good) out of a maximum of 9.
Hope that makes some sense!
Well duh. :p
If you wanted to do an Italian team, or hybrid you could. You could link up Ballotelli with other Italian players who play in the premiership. Like Borini, for example. But there aren't too many Italian players in the EPL.
You can then use links from Borini to bring in Premier League players. But if you did say: Hart, Walker, Chellini, Terry, Ogbonna, De Rossi, Gerrard, Pirlo, Ballotelli, Di Natale, Hernandez - this wouldn't work great as you'd have weak links everywhere.
