- 23 Mar 2011
The auto aim is an setting in the options so you can turn it off if using kb&m.
Oh thats good then thanks
seemed a bit overkill in the vid i saw so glad this can be turned offThe auto aim is an setting in the options so you can turn it off if using kb&m.
seemed a bit overkill in the vid i saw so glad this can be turned offOnce it's unlocked, am I going to have to be playing this with a VPN on everytime until it unlocks in the UK?
Unlocked with spotflux, but is it ok to play with spotflux enabled cos I want my friends etc still connected or will it slow my pc down or anything?
This pre load on the VPN is taking AGES! Already pre downloaded the files but it's still asking me to pre load?
I chucked steam into offline mode for now. Not that fussed about being online.Cool, workingI chucked steam into offline mode for now. Not that fussed about being online.
Played around with the settings, not that much PC option??? Don't know why reviewers were happy about the amount of customization. It's basic texture, brightness, rat shadows and shadow detail. And FXAA... So nothing new.
Chucked on SweetFX at default settings. About to get cosy and get stuck in!
I thought that as well... Wasn't a great deal to select in the graphics options. Reminded me of RAGE once they updated it, that had similiar graphics options.. although 'rat shadows' lol someone has a sense of humour at Arkane Studios..
SweetFX made the game look brighter, and cleaned up a few bits, looked sharper, I'll get stuck into my game later this evening once the kids are in bed and missus is busy with some junky telly or something...
Can someone tell me why they just cannot release games to the world the same day?!?
no idea but its really annoying -.-
Yea graphics are awful. They need to release a hi-res pack.
You can mod a lot of options like shadow resolution etc in the ini files though. I'm looking forward to someone releasing a tweak guide with all the ini settings. Both AA settings are average at best, need to look into a good injector.
Gameplay though is fantastic![]()
Seems very bethesda-ish. Skyrim out the box is OK looking, but the textures are horid and a few simple ini tweaks can transform the game.
