- 11 Oct 2012
I have spent the day reading about tuning my 7970 and have ended up with the following in Afterburner.
Core 1093
Power Limit +20%
Core Clock 1152
Memory Clock 1501
With stock cooling the temp stays around 65/70 degrees under load.
I have set the display options in SLEEPING DOG to EXTREME. I am only getting 28/34 fps. What am I doing wrong? I thought that this card would run any game at full settings at 1920 x 1080 at 60fps.
I will have the 7970 running 3 x screens next week for games. My £400 investment is worrying me
Is this normal performance for this card on stock cooling?
If so what "reasonable" water cooling do you recommend to get the frame rate up bearing in mind I will be using 3 x 1920 x 1080 monitors in eyefinity mode.
Thanks
Paul
Core 1093
Power Limit +20%
Core Clock 1152
Memory Clock 1501
Thanks
Paul
