Fifa 13
Had enough of this piece of **** now. Was on 12 points and clear from relegation in division 1. Play my next match the game crashes to desktop about 70 mins in. I come back on as expected it says did not finish modifer bla bla bla but then it's restarted the season and not given me any coins for the last season. Division 1 is also full of pace abusing **** holes.
Thats your pc's fault. millions of others run this game flawlessly mate. check your drivers etc.
what my 1v1 will fix is for u playing against light minded people
It's not my PC's fault so stop making assumptions. It runs prime or heaven stable for hours on end. Every other game I own works flawlessly. A quick google search throws up loads of people having the same problem.
loads? how many? u know the saying, the people with issues are always the one who are the loudest while millions who dont have issues are quiet and satisfied.
Also, my 1v1 league doesnt have that coin BS as well so another reason to join :)
If your a stat/achievement whore, by all means stick with playing regular ranked 1v1 in fifa :)
fix your pc, see what else is running in your background, reinstall the game, try on a different hdd. Try on a different pc etc etc.
My PC doesn't need fixing. I told you it's stable in everything else. Also where in my post did I mention I wanted stats/achievements?
As usual you are just talking nonsense and not helping anyone apart from yourself by trying to get people to join your 1v1 league.
Also I've seen people in this thread complaining about crashes as well.
Quote from another forum to shut you up:
A lot of people are having problem with crashes. I talked to EA support yesterday and they said that they knew about the problem and that their developers are working on it and there will be a downloadable patch soon. How they define the word "soon" , I dont know.
i tried to blooming help u. i suggested ways u can check your pc. but u dont want to listen so there u go.
I've already checked it which I told you but you seemed to completely ignore the matter. It can run prime 95 for 24 hours, heaven for 12 hours, BF3 for 8 hours at a time. Yet somehow FIFA 13 makes it crash because it's my fault. I don't think so lol.
So u reinstalled the game as well?
Have you tried deleting your temp files? When I first installed Fifa it would crash to the desktop every time I loaded the game (which is a common problem and will be fixed in the patch), I cleared my temp folder and it worked. Fifa hasn't crashed since. It may help you, probably not though.
Im having really bad issues with FUT , worked fine and now is not launching at all.
Was one of the reasons i havent bought a FIFA game for a long time , just no after sales support . Basic replies of you need to open ports.........
I do love it when I can get a game out of it , but this issue is really bugging my **** off!
