You have AC??It's an '02 Astra 1.6. Pretty sure the pollen filter was replaced on its last service, but I'll double-check that. I do have AC but only tend to use it during summer as it impacts performance, but I'll give that a go and see if it does the trick. Think it's probably worth giving my windows a good clean too, maybe that'll help.
Use it!
You get conditioned air which is cold. Unless you turn on the heater, in which case it's hot.What exactly happens when you use AC with heat? Never really tried it, does the compressor still come on etc? Wouldn't this just make everything cold?![]()
I only really use it in the rain as the windows will fog up quickly.
And when it's hit and stuffy in the car, obviously.
It's noisy though, hence not using it 24/7
