Rusty, we can easily do 1080/1440/eyefinity too to give us a wider scope so feel free to pitch in![]()
Yeah Rusty (poke in the rib)
. The more the merrier.Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
. The more the merrier.Rusty, we can easily do 1080/1440/eyefinity too to give us a wider scope so feel free to pitch in![]()
Yeah Rusty (poke in the rib). The more the merrier.
just installing 12.9 betas now (was on 12.8 with beta driver) and re-installing AB 2.2.3, 2.2.4 went ape poop on my clocks.
. I've been hearing a lot of good things about these drivers. Are you on water for 1350Mhz?.I seen and wilfully ignored that on the grounds of the 1080/1440 results.
I hear you if you're done fiddling. Getting old?. haha sorry I can't help myself.
I might lean on you, Tommy and Gregster for 3D when I'm up and running so please forget that I'm teasing you here.
Hey, hey, hey Nvidia users, hey!
Look what I can do at the click of a button:
Duplicate my three screens
Extend them
Eyefinity them
/annoying orange
But in all seriousness, from a sanity viewpoint, AMD owns at 3 monitors
All good things come to those who wait. I've been hearing a lot of good things about these drivers. Are you on water for 1350Mhz?.
I can bench CF 7850s and CF 7970s.
As long as there is a thread to go to, with what games and which settings i'll happily join in.
I can do that too
What I was talking about was that when I last used nvidia with 3 monitors, it was a PITA switching between modes. Eg, I want to work and want each screen to display something different (Extended mode) I need to arrange the desktops. Then if I want to play BF3 (Eyefinity/surround) I need to setup a surround group. Once I'm done, to go back to extended, I need to set it up again. Sure, it only takes 2 mins, but it's still damn annoying to do every single time.
With AMD you set it up once, right click and select whichever option you want to use for 3 screens.
Yer ok, that hasn't changed. I have not looked for saving profiles though but it is a PITA.
If it wasn't so much of a pain, I'd bench. Alas it's more of a pain than banishing VRAM hoodoo's.
Greg is better. I don't play much in 3D unless I'm just chilling. If I want to do well in BF3 it is most definitely switched off!![]()
.It is a pain unplugging monitors and enabling/disabling multi monitors. Also I find it is better to remove the second card but this isn't essential.
Happy to help with any question with surround/3D![]()
lol Cleeeeeeeeeeeeeeeeeeee. You can also do this with Nvidia but for best results, I will be doing it as though I have a single 680 on a 1080P monitor. Also I can make any game I have 3D simply by clicking a start menu button 'enable 3D vision' or I can click 'disable 3D vision' and this then enables all my 3 screens to output in wonderfull 3D or 2D depending on my choice. No messing and fussing just as easy as that![]()
. I was hoping that it would let me run everything nearly at full with 3D. I take it can do this and more @ 1920x1080?. If so then what could I get for supporting screens?. I've still to get my QPAD-MK85, R.A.T Mouse, Corsair 750w Gold PSU, extra pair of glasses, plus the Asus VG278H. I'll most likely have to wait. If I send this back I think OCUK will ban me from buying as I've already sent back a 670 and 7970
.Yep, though 1200/1600 is destroying everything I throw at it.
680 SLI? More than enough for 1080p 3D max settings.
yes ? so ? and ? I bet the same crashes are not fixed on the official
