De-lidded 3770k!!
15 May 2012
Louth, lincs
*WARNING*
This will only work on IVY's, sandybridge heatsink top is soldered.
well got a 3770k about 5 days ago and after a little play i thought temps were a little high!!
this is running prime for 10mins @4.4ghz/1.25v
so did a little reading and thought what the heck i'm gonna have a go!!!
plus going under water so thought that it would benefit from the operation.
lid on.
Under the knife, slowly slowly!
voila, lid off!
time to clean that mess off, did it the best i could for now as i need some better tim, used AS 5 for now.
all back together in my PC, it fires up!!! nice, i've not killed it!
right same test, 10 mins of prime and NO settings changed.
Well i'm happy with those results, took me half an hour from start to finish, well worth it, and the temps should get better when the tim cures a little:D
did you nik the pcb underneath at all? its very easy to destroy the chip but well done
btw what cooler did you use??
no, theres a very tiny mark but i wouldn't call it a scratch.
once i freed a corner enough to get the tip in it was easy. Iwas more worried that the tip of the blade would snap, but all was well ;)
did you just push in the tip of the blade all the way around? i have to admit its rather daunting,starting off is the worst part
using just the blade on a corner just rocked it side to side, you do need quite a bit of preasure but once through just ran the tip round, had a picture of someone else's next to me on my ipad so i could roughly judge how deep to go in. The top and bottom is the risky bit as the core is quite close.
Nice! Was gonna make a thread about this as well. Do you still have the IHS on after replacing the thermal paste?
I found that I got 10C difference just by replacing the thermal paste, and another 10C+ difference with the cooler directly mounted on die, so a total of 20C+ less temp. I'm able to run it at 4.8Ghz as a result.
So I assume the fact AS5 is capacitive doesn't cause a problem?
it appears not too.
yeah the IHS is back on, once underwater will have a play without the IHS and with some liquid pro which is meant to be about the best replacement.
and a 20c drop is quite an achievement :cool:
One Brave person, can you do mine when i get it ???
i have only done it as its going in a water cooling setup, where its meant to help. It is not advisable for all.
4.4ghz is more than enough which should be easy on air, anything more is just bragging rights :D
