Caporegime
- 8 Jan 2004
- Rutland
Remember doing the same on the old athlons, not for the nervous.
Very nice. Have you been able to push the frequency up as a result?
In theory it should be yes, though I would imagine you stand a chance of damaging the die which = dead cpu
Btw, you have balls of steel![]()
It can, but IMO its another pointless exercise that could result in a dead CPU if you're not careful.
Lapping may give another 2-3c I would say at best.
I thought about this but I am a clumsy oaf, so it's a no noWell done for being braver than I
Crushed core, dead chip.
Best cooling performance is to go naked. It should allow you to reach similar clock speeds and temperatures to SB.
Edit: You need to make sure your cooler can compensate for the difference in height.
No IHS.
So I assume the fact AS5 is capacitive doesn't cause a problem?
