- 18 Feb 2007
- London
new update for granny Smith, levels have been slightly changed and it's much easier!
Is this the space level, I got past 1st and gave up
Is it still only available from xda via a guys nightlys thread, or are they officially releasing it now?
Time-lapse photography is a technique whereby the frequency at which film frames are captured (the frame rate) is much lower than that used to view the sequence. When played at normal speed, time appears to be moving faster and thus lapsing. For example, an image of a scene may be captured once every second, then played back at 30 frames per second. The result is an apparent 30-times speed increase. Time-lapse photography can be considered the opposite of high speed photography or slow motion.
Processes that would normally appear subtle to the human eye, e.g. the motion of the sun and stars in the sky, become very pronounced. Time-lapse is the extreme version of the cinematography technique of undercranking, and can be confused with stop motion animation.
Could I use tasker to do the following?
via NFC tag or starting an app:
Turn on bluetooth
Connect to a known device
Start a music player app
Told you it was a great app![]()
Yours did well to not auto adjust exposure too much.
Time to get that!
Edit*
I have FB/Tweeted it and put in a mention- https://www.facebook.com/khanphoto
Hi guys, trying to use Dolphin Browser, i've downloaded the Jet Pack add-on, but when I go into the browser and into settings then addons I can't see it there? Only things like settings switcher, speed test, smart search etc?
Is there any reason why the widget doesn't work for me? On my One X and my Nexus 7 the widget just says "No upcoming calendar events" but when I click into it, it shows all my appointments, of which there are quite a few.Google have separated the Calendar application from the main ROM and have it as an upgradeable program:
