Lol Minis with spoilers...
Blackhawk47 wins this thread.
But......... They come with spoilers.
I can't think of many production 140mph hot hatches that don't come with a spoiler regardless of their usefulness.
Even my Yaris has a spoiler
Question - Is it only the Mk1 Mini has the air intake in the bonnet? Or is that only for the JCW?
http://sphotos-f.ak.fbcdn.net/hphotos-ak-ash4/p206x206/2888_78072824676_3263689_n.jpg[IMG]
[IMG]http://sphotos-e.ak.fbcdn.net/hphotos-ak-prn1/p206x206/27763_397115139676_1288334_n.jpg[IMG]
Owned the first when I was 17, promptly crashed it into the back of a van and bought the second. Miss them a lot, would love to have one as a second car.[/QUOTE]
Get it done mate! :D
I think they hold their value really well and will only go up in value in the future. ;)
I could probably afford it but having 2 cars as a student when I do approx 100 miles a week in total is... needless.
I'd find an older one and get it tax free. That way if you are not using it you're practically paying nothing to keep it on the road. At the moment my mini costs more than the A1 to tax.
How's the MX5 going?
Rolling shell: Prepared to full Miglia spec by Peter Vickers, rear seat pan/storage bins removed, laminated screen, polycarb windows, steel doors lightened to Miglia spec, front end removed & replaced with removable carbon fibre front end & bonnet. Front bulkhead/parcel shelf removed - new bulkhead & dash fabricated, wrapped around additional bracing bars, fully integrated into Safety Devices bolt in & welded in full cage with further bracing to current Miglia race specifications. Boot floor removed, alu sheeting & foam filled race spec fuel cell with sump & lock, Facet race spec interrupter fuel pump & filter in boot, carbon fibre bootlid. Braided fuel lines & copper braking pipes routed through inside, brake bias adjuster beside gearshift. Gearshift mechanism/quickshift with 2 UV joints fitted inside car. SPA Design firex, electrical control box & special loom, aircraft switches, ignition cutout, start button fitted to passenger side on floor. Instruments: Stack RT 400 tacho with datalogger 0/10k, Racetech Design combined oil pressure/water temp gauge. Sparco rev seat, Sparco steering wheel, Luke harness, Varley Red Rop solid state race battery. Racetech big capacity alloy racing radiator, new 115 comp alternator.
Suspension: front & rear subframes fully seam welded, gussetted, strengthened to Miglia spec., brace bars fitted to front subframe, dampers: TrackSpax at front, Avo at rear, original Ripspeed Hilos, Minispares race rubber cones, KAD adjustable rear camber brackets, custom built rear antiroll bar, KAD rosejointed front lower arms & racespec adjustable tie rods. New Lloyd Hutchinson quickrack.
Brakes: KAD race alloy 4 pot calipers, 7.9in vented discs, carbon metallic pads, Minifin alloy rear drums with Mintex race linings, Goodridge braided hoses front & rear.
Wheels & tyres:
1 x set Revolution alloys 6x10 - Avon CR6ZZ E rated control race tyres.
1 x set custom split rims alloys 7x10 - Dunlop Slicks
Engine/gearbox new May 2006 - Lloyd Hutchinson built
MED supplied head, offset valve race spec No: 1187MED, fitted 37.8mm inets, 31mm exhausts, Iskendarian race double valve springs & caps, Titan 1.5 full roller rockers. Block MED 65400LW 1425cc, A+, full race prepared, offset bored & honed, Omega 11mm dish pistons, new Cooper S rods, relieved & balanced, crank stroked, relieved, wedged, balanced, 4 bolt steel centre main bearing cap. Comp oil pump, Kent 310 scatter pattern billet cam, lightweight race duplex gear, etc, filter head drilled, tapped & bypass plugged, ARP race spec bolts throughout. Lightweight race steel flywheel & backplate, race paddle clutch, Brise reduction gear starter motor.
Gearbox late spec casing fully machined to take very latest current spec Quaife dog gear set, LSD, race straightcut drop gears - 1.0416, centre oil pickup, race output shafts & bearings, semi helical final drive. Ratios: 2.309, 1.49, 1.197, 1.00, final drive 4.07. Primary gear 24 tooth, effective final drive 4.239. KAD Quickshift.
Carburation: Weber 45DCOE tipo 152 on Maniflow 7in steel inlet (new 2005), MED integrated filter/induction box with revised carb trumpets (new 2006).
Ignition: Aldon Automotive race distributor & ignitor pack, Luminition blue silicone 8mm race leads, Aldon epoxy solid state coil - all new 2006.
Exhaust: Maniflow big bore race LCB with matching Maniflow exhaust system, single box silencer, centre exit.
Power plot - dyno sheet available: Tested at Westward Engineering 24 May 2006, newly built, ambient 14c, barometric 1000mb.
Max torque 107.10 ft lbs @ 5312 rpm
Max power 119.7 RPM @ 6991 rpm
Power loss, trans/tyres 19.4 bhp
Power at wheels 100.3 bhp
Max road speed in test 98.00 mph
Max engine speed in test 7655 rpm
Lol, I love how this thread is full of members own Classic Mini's, and then a bunch of other peoples BMW Mini's![]()
MX5 is flawless, only non service items were a rocker cover gasket and a fan belt change due to occasional squeeling.... gone through an MOT with zero advisories and still has absolutely zero rust. I love it to bits and I can't decide whether I want to replace it (Z4, 350Z) or just tidy up the few messy bits (laquer fade on the lights, drivers bolster, scuffed wheel arch) and spend a bit on a suspension refresh.
How is insurance on the Mx5, I remember when I was 18, looking at first car etc but found the mx5 quite expensive compared to other cars I was looking at. Suppose it will be much better now, how much are you paying if you don't mind me asking?![]()
