	Just Cause 2.
CPU; Phenom II x6 @ 4.1Ghz
Gigabyte 7870 Windforce 3x (Catalyst 12.8)
In-game benchmark used + FRAPS
1000 / 1200: Min 68 / Max 106 / Avg 86.074
1100 / 1200: Min 72 / Max 110 / Avg 89.772
1200 / 1500: Min 82 / Max 130 / Avg 103.188
Nice looking game, does it have Physx? looks like it might have Physx...
Also is it just one on those where you look at your guy? or can it be set to first person?
I hate that where you are behind your guy.
Lol higher averages than both me and Pgi using 1200/1600 with 7970s.
What benchmark were you using? (We used concrete jungle one)
Hmm, seems a bit low?
Using all latest drivers and at 1050/1575.
Yeah, i noticed that.
It didn't say, it just said benchmark, no options to change it.... some red desert with a small town flyover...
Needs more threads?Gregsters 680's were being bottlenecked by his 2500, so could possibly be the same case here.
Oh...Swear you get to choose? Just as you click on the benchmark there's 3 options.
	Possible, best off speaking too gregster or others with dual high end cards, im only running a single at present.
What mobo board you running?
This is all i get.
If i click on that it starts the benchmark.
(Demo v 1.0.0.1)
OH! It's the demo?
Might make more sense me and Pgi redo using the desert benchmark instead.
Whats your gpu usage when running bf3?MSI P67A-GD53 ^_^
GPU usage is usually 50-70%Whats your gpu usage when running bf3?
Can you clock your 2500 higher??
Do a quick bench and check gpu usage, then try and up your clocks on cpu, run same bench and check gpu usage again.
Yep, my CPU usage is maxed out pretty much all the timeBottleneck![]()
Yep, my CPU usage is maxed out pretty much all the time![]()
