Win8 Tablets
Asus Taichi with dual 1080p IPS displays (it's not a tablet though). It's a crazy idea but i like it...
I don't see any RT tablets with more than a 720p display or am I reading it wrong. Seems to me that if you want 1080p you have to go for Pro.
That's kind of annoying if true.
Announcements still coming, surprised.
Waterproof and dust prove, could come in very handy.
Fujitsu ARROW tab QH55/J
price:
release date: 26 October
101 IPS LCD
574g
Atom Z2760 @ 1.5Ghz
2GB Ram
64GB
2-megapixel front camera, an 8MP rear-facing camera
9.9mmx264.4mmx169.4mm
Wi-Fi 802.11b/g/n
Bluetooth 4.0
GPS
accelerometer, gyroscope, and an ambient light sensor.
MicroUSB port
MicroSD
IPX5/7/8 water-resistant
IPX5 dust resistant
7 IPX5/7/8 water resistance:
The tablet maintains IPX5, IPX7 and IPX8 water resistance when the cap for the external input connectors is firmly in place. The IPX5 designation indicates that the tablet can normally function after being sprayed with water from a nozzle with a diameter of 6.3 mm at a rate of 12.5 liters per minute from a distance of approximately 3 m for a period of at least 3 minutes. The IPX7 designation indicates that the tablet functions normally after being immersed in room-temperature tap or still water to a depth of 1 m for 30 minutes. The IPX8 designation indicates that the tablet functions normally after being immersed in room-temperature tap water and standing water to a depth of 1.5m for 30 minutes.
8 IP5X dust resistance:
The tablet maintains IP5X dust resistance when the cap for the external input connectors is firmly in place. IP5X indicates that the device can be left in an environment with dust particles with a diameter of 75 µm or less for 8 hours, and continue to function and be used safely.
Fujitsu ARROW tab QH77/J
price:
release date: 2nd of October
11.6" 1366x768
850g without dock and 1.7kilos with dock
4.8hrs without dock, 10.7hrs with dock
302 x 195 x 12.7 mm without dock, 302 x 203 x 26.1 with dock
Wi-Fi 802.11a/b/g/n
Bluetooth 4.0
HDMI
one USB 3.0 and one USB 2.0 ports.
5-megapixel camera on the back, a front-facing camera
SD card reader
fingerprint reader
Found another one, seems expensive for what it is. Comes with w7 but with win8CP file for you to instal. Would require the upgrade purchase.
But by God their website doesn't work in safari and they can't make up mind on 32 or 64GB ssd
Viewtronicx M3 Touch
release: now
Price: $699
Keyboard dock. $59
Dock $??
11.6” Multi-touch screen Tablet PC Running on Windows 7® Home
Processor: Intel® Pineview-M N450 + ICH8M, 1.66GHz , 667MHz, 512K of L2 (200MHz)
Casing: Magnesium Aluminum Alloy
System Memory: DDR2 800MHz 2GB, 1 SO-DIMM slot (Max 2GB) Actual performance at 667MHz
Screen: TFT LCD 11.6' HD GLARE (1366*768) Multi-touch (Real two points)
Graphics: Intel Integrated Graphics Media Accelerator 3150
Mass Storage: SSD 32GB (up to 64GB) by Mini PCI-E
Bluetooth: 2.1+EDR
Size: 11.61 x 7.68 x0.55 in (or 295 x 195 x 14mm)
Weight: 2.18lb
Battery: Embedded Lithium-ion Polymer 2-cell (7.4V, 5000mAh, 2S1P) Battery Life: 4.5 hrs.
Camera: 1.3M pixel Webcam
Interface:
1x DC-in
2x USB port
1x OMTP jack
1x SDHC slot
1x SIM card slot
1x Mini-HDMI (up scaling 1080p from 720p source)
1x Hotkey
1x 26 pins connector (for Docking
G-sensor: Display orientation (3-axis sensing)
WIFI: 802.11 B/G/N
Audio: , 2 x 1.5W speakers, and 1 built-in microphone
FREE pre-paid 3 Month Subscription to Netflix
Options:
Docking Station (Sold Separately)
Why are they all missing one feature I want. This looks nice but no 1080p screen :mad:
Futjitsu - Stylistic Q702
Release:
Price:
11.6" 1366x768
I3 @1.8GHz or i5 @ 2.8Ghz
64,128 or 256GB SSD
4GB Ram
Bluetooth 4.0
3G/4G
Wifi a/b/g/n
1xusb3.0, 1xUSB2.0, 1xHDMI, 1X VGA
302mmX195mmX12.7mm
850g, 1750g with keyboard
4.5hrs, 9.5hrs with keyboard
Fingerprint reader
5.0mp camera & 0.3mp camera
Stylus
Dell - Lattitude 10
Release:
Price:
10" 1366x768 with gorilla glass
Atom CPU
2Gb RAM
32,64 or 128GB
removable Battery
Micro SD
Full sized USB 2.0
SD up to 128GB
Mini HDMI
MicroUSB (charging only)
3G
10mmX??X??
789g
2 or 4 cell battery latter giving upto 18hrs of usage.
optional
Keyboard Dock (4xUSB2.0, HDMI)
Stylus
Charging dock, to cobpnbert to desktop
It does look good. It's not a powerfull chip. Think of it as equivalent power to arm chips. Fine running office tasks and media, don't expect it to play games though.
Clovertrail is about the same speed as the current high end atoms, so it wont run intensive games like battlefield, or any serious pro apps (maya etc.). Will probably be just enough for basic work in adobe apps and should run most normal apps like office just fine. According to Intel's internal testing it's significantly faster than Tegra 3 and S4 dual, but we won't know for sure until reviews are out this/next week.
Thought this was pretty cool, the 1992 think pad tablet next to the 2012 think pad tablet 2.
http://www.flickr.com/photos/lenovophotolibrary/7746378872/
Lightroom also apparently has issues on 32-bit computers (all clovertrail tablets are running 32-bit Windows).
Do you think you'll go for the Surface pro or something else?
I really want them to release the prices so I can decide whether to get one or wait!
At the moment I think it's
Asus transformer book (looks like no 3G/4g)
Kupa ultranote even though the keyboard dock is fugly (no 11.6" screen, fugly)
Surface pro (no 11.6" screen, no 3G/4g)
The other option is buy a second hand win7 tablet like the Samsung series 7 upgrade it to win8 and wait till the next round of tablets in the new year. I find it hard to believe MS won't add 3G/4G, or competitors won't up their game.
However I cannot wait around for ever, the screen on the ipad is getting worse and worse, so if surface pro isn't out till jan, then it's a no go straight away, unless I buy a stop gap win7 tablet. I just don't think the screen on ipad is going to last long and it's uneconomical repair.
