why is this not advertised anywhere on the site... bit reluctant to put my Origin Id and password into a webpage...
surely they could have just checked your eligibility in origin itself
Anyone had any luck getting this to play? I see people are in playing MP so there must be a way.
I'm connected via a Korean proxy and the game is fully downloaded but says that the game has not been unlocked when launching...
i Just used a vpn and unlocked it... went to the start up screen and exited out... turned the vpn off now its locked again...
do you have to run the vpn software all the time? i thought once its unlocked it stays unlocked.
Not sure either. I was the same - got in but can't play as it's not release date on normal IP.
I guess now it's been unlocked you can just use a proxy to play? Trying now...
Edit: yes, you activate it through the VPN and then just use a proxy through your Internet settings in CP and it works.
battlelog is no longer working for me..
How did you do it? Did you use a VPN first like flyvpn? Or unlock using IP proxy in control panel?
Unlock through flyvpn; play through a control panel proxy. Once it's unlocked you can play it through a Korean proxy. It's the unlocking which requires flyvpn.
Whats OpenVPN tap driver? It keeps asking to install it. Looks a bit dodgy.
Its fine![]()
