9th, i was looking at the wrong graph!!![]()
Phew...I was getting worried I had messed up
Totally agree with thisMaybe more perf in the future for GCN too. Lets see how much more improvement AMD can make with it.
Btw..wish i had been a fly on the wall at Nvidia head office when the Cat 12.11 news got back to them![]()
Phew...I was getting worried I had messed up![]()
It seems to me that these drivers have made the 7950 closer to the 7970, I was just looking at Matt's score of 12071, which is only 4% more than my 11612 (graphics scores we're talking about here)- despite his being clocked at 1270/1900 as opposed to mine at only 1250/1700. I would have thought there would be a bigger difference with the extra shaders and higher clock speed of his 7970.
I'll run mine at 1250/1700 to compare Nuclear.![]()
I'm surprised there hasn't been one of those hitler rage videos made of it by now![]()
Ah thanks Matt, good to do a like for like comparison
I would say I'll try 1270/1900, but my card was getting hot enough as it was. Is yours a lightning?
Nah its a reference, and to be honest the max stable is 1250 on the core, though i never normally run it above 1225.
Memory i normally never run over 1719, but i believe it can go up to around 1850-1900 when i put the volts up, though ECC may have been kicking in around that, not sure.
http://www.3dmark.com/3dm11/4735578
@Nuclear & Matt.. what volts u using on mem for 1700?
Thanks for running the benchmark, 11719 is less than 1% faster than my 11612 on the same clocks, which is surprising as most people say that the 7970 is around 5% faster at the same clocks. What max temps were you getting? Must have been pretty hot with a reference cooler![]()
I used 1687mv, but I can probably use lower, I just wanted to make sure it wasn't error correcting (hence reducing performance).
I didn't touch the volts on that, i was also using a different bios, ill switch back to my stock one and see if results differ.![]()
Gregster could you update my single GPU score please (post 1631)
It puts me 1 point above MyBrains HD 7950
Every point counts he he.![]()
I have been doing 10 things at once today or trying to and actually doing nothing
Consider it done bud.Thats not gona last![]()
