Gigabit Internet Speedtest
22 May 2007
UK
For those that wish to know here is a gigabit internet speedtest result obtained when testing against the nearest server...
So now you know what to expect from a gigabit fibre optic connection.
There are technical reasons which means that *only* 564mbit/s download is really rather good.
Its an improvement over the 100mbit/s connection anyway.
Then they should not be selling it as 1Gb, as you can't actually get that.
Wouldn't be the first time a broadband supplier over sold their service. Technically they can call it a gigabit because it is based on gigabit technology even if you cannot actually attain that speed.
Its like when I had 512kbit/s ADSL which if you convert to bytes by dividing by 8 you get 64Kbytes/s. I never saw a download above 55Kbytes/s meaning the connection was maxed out 440kbit/s a little way off the theoretical 512kbit/s.
Yes but overheads on a gigabit link should see you reaching throughput somewhere in the region of 900 to 960Mbit/sec, not 565Mbit/sec.
It's true that it's still very fast, but it shouldn't be sold as gigabit if customers are expected to see over 400Mbit 'overheads'. A few percent overhead is a reasonable expectation but 44% is not :)
It's like advertising broadband as up to 8Mb, when the max one can get is actually 7.15!
While I agree that the ATM overheads thing was a bit of a joke, at least 7.15Mbit was 89% of the maximum. In this case the result is 56% of the maximum.
However let's be honest. If you're seeing over 500Mbit on a home connection then you're going to be more than happy anyway. There's also the possibility that speedtest.net's servers are actually a bit crap and you'd see higher throughput from elsewhere.
The speedtest in the OP is bits per second. A 1 Gbit connection can reach 1Gbit download speed.
Please, enlighten me as to what these technical reasons are.
Its not the first time, but that doesn't make it right.
The OP is getting almost half what he is paying for!
