- 22 Jul 2012
- London
Is that with the Peter on as well? Bummer. I run my reference at 1100/1575 on stock just so I don't have to muck around with extra cooling and AB. It'll do 1200/1650 but the fan is so loud and I can't be bothered to spent the extra £50 plus for that extra 100Hz. My chip is very similar to matt's Voltage wise though so I might see if I can get a little more out of it at stock, maybe with the unlocked Asus bios...
Yeah, Peter's doing a good job but I get the feeling he'd like a bit more of a workout
I needed better cooling at those clocks anyway, so I don't regret the purchase at all.
Really should've saved money and taken my chances with a reference card in hindsight, but then the whole Alpenfohn extravaganza wasn't planned back then and I was coming from a noisy ref 5870 :/
It's not like there's any missed performance or anything though, it's just the satisfaction of hitting the magic number y'know
MSI 7950 TF2 V2?
I'm able to get 1200 core on my TF2 (version 1) but have to raise the volts slightly above 1.2 which I don't want to run at 24/7.
Anyway these drivers are getting 4 fps more in Heaven compared to 12.8.
Not loads but free all the same![]()
Sapphire 7950 OC 950mhz Ed. I have increasingly been thinking that the TF3 is the safer bet, but too late now.
No biggie, but it does suck a little if you're into tweaking the hell out of your rig
