Thank you.
You can actually use a thin piece of plastic to do the job the sealant isn't tough at all. It's just silicon based I guess.
The razorblade was all over the place, was a disaster, really needs to be a solid blade or plastic. I started the cut with the razor blade and I think it got it after that, because it's bendy and hard to control.
Stanley is best because it doesnt bend, and will stay flat against the PCB, you can also just gently wiggle it through the sealant avoiding the die.
If I get a really blinding chip I will be tempted to delid it.
Waiting for a response from someone, because I'm not sure how OCUK feel about the 14 day DSR for high volt chips, I can't bare to have anything over 1.1950VID.
Need one fast as the hard drive on my back up pc is ruined and manages to lose vital windows files every day.
Nor the money for it!
