yeah 4.5ghz,1.212v so far im still tweaking,+0.020 dvid and llc high,im using a silver arrow cooler though and just one fan atm
Wow, that's a good chip mine was 1.28V for 4.5GHz, +0.090V. If lower offset some games would crash when minimizing and resuming, I assume because of the C1E not using the right voltages, but was fine at +0.090V and "low" LLC.
Very very tempted to de-lid my i7 3770k as im currently hitting 80 degrees under a custom water loop @ 4.5ghz and was hitting 92 degrees at 4.6ghz and that's with pretty low voltage
Gutted for you Brian and its put me off a bit but I still keep thinking about it, I have brand new Stanley blades or a full craft set of scalpels I can use, hmmmm.....
Thanks!
 I will still be tempted, I think if I upgrade D-14 to an Everest or watercooling I won't be bothered to remove the heatsink again. I think it would be easier if I used the right tool, but the PCB is so very delicate I'm scared to do it again. Once you take the IHS off it feels like a whole new thing, it feels weightless.80C is fine for these chips isnt it? What is temps during normal use that's all I go by on these chips myself. Mine was under 60C on normal load in games so I was happy with that at 1.28V, Prime95 was just to test for stability rather than temps.
 Wanna trade? I have a delidded 3570K ...XD
