Omelette
5 Jul 2006
Just looking for some advice
Every time I make an omelette its fine around the edges, but still a bit runny in the middle!
Can someone tell me where I'm going wrong?
That's perfect! Although if you don't like it then you can either flip it or stick it under the grill for the last little bit of cooking.
Never thought of flipping it actually! I prefer it without any runny stuff in the middle :p
how thick are you making it? Have you tried putting it under the grill to brown the top?
Not overly think or anything, 3 eggs in a medium/large pan so it has plenty of room to spread out
Omlettes need to have some moisture in them. A bit thick and gooey in the middle sounds fine to me.
Nothing worse than an omlette like a frisbee.
Yeuch.
Tip the pan while you're cooking? Let the runny stuff run to the edges, where it'll then cook quicker.
get the pan heated up and then chuck the eggs in but keep moving them about for a bit rather than just leaving it, make sure you don't do it to mcuh or you end up with scrambled eggs! that way you can ususally judge it to be cooked but not over
I "pull" the edges in with the spatlua whilst tipping the pan so the uncooked egg runs into the void made. Keep doing this till most of it is used up, then fold the thing and press down with the spatula for a final burst cook of the middle.
Get it done :D
Yep that's basically the way to go. I'd spent years making rubbish omelettes before realising this trick.
This way, it will be just set and the texture should be near to perfect.
that needs to be flipped
1. warm pan
2. thin layer in pan
3. cook first side
4. flip
5. add filling
6. fold
7. cook a bit
8. flip folded omlette
9. cook a bit
10. serve
This is what I do:
1. Cut up fillings (bacon + tomato is my current favourite)
2. Fry them (almost fully cooked)
3. Beat eggs salt and pepper a bit in a mug
4. Add egg in pan
5. Drain the runny bits towards the edges
6. Fold
7. Serve
