- 10 May 2004
- Middlesex
Hey guys,
My parents have an old PC which they would like upgraded to a HTPC *if possible*. I've got a couple of questions.
This is basically all I will be carrying over:
Pentium E2200
Acer - F672cr-R01-A4 mobo
OCZ Vertex 2
I guess my first questions is, on win 8 will this be ok for 1080p video (I will be buying a gfx card)?
This is the case they would like:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-163-SV
I'm finding it very difficult to find documentation on the motherboard, I think it should fit in the case but could anyone confirm?
The other problem I have is there are only 2 sata ports. I will have a vertex 2 and a storage drive but they will also need a DVDRW in there. I have seen sata>IDE converters cheap on the bay. Do these work?
Right, if everything there checks out and will work together can you guys help me spec the rest up please?
I'll basically need everything else to go along with the above (excluding keyboard, mouse, speakers). They will need a GFX card that fits in that case which has an HDMI out and a wifi card or USB wifi dongle and it will need to be as quiet as possible at about 7 feet. It's currently using the intel CPU cooler (will this be quiet enough?)
Budget is as cheap as possible really.
I know it's quite a lot to ask but any help will be much appreciated.
Pentium E2200
OCZ Vertex 2
