- 15 May 2012
- Louth, lincs
Thx, for me using the stanley was fine.
very brave to de-lid indeed.
, late so will tune and post more pics and and give more details later.
Confused as to why you'd need more than 1L of fluid to be honest if you're only doing the CPU, unless the tubes are going to the Alps and back?
Mine is on GPU + CPU with a 360 rad and takes less than 1L with a 250mm res.
Nice system, what TIM did you use for the cpu?
Surely that has to be the thickest radiator posted on this forum so far?
I think I will go for a smaller rad myself, look's better to my eyes. I do like how BIG your rad is though. Think I can get a 280mm up top in mine but will be using a 240mm most likely.Have you not seen the monsta's before??
