- 9 Dec 2009
- Bristol
How can you improve cooling over soldered though?Direct die?
Don't delid,its just pot luck that you pull it off,I've seen two dead chips now and two successes
If only they sold something that dissolved the bonding agent,instead of cutting through it
I didn't enjoy a single moment of delidding mine.I would buy delidded/sealed ones but wouldn't risk it myself again.
i loved every minute and if i got another hot chip i'd do it again.
Nonsense. If you do it properly it's really hard to kill your chip. I've seen about two dead chips and probably 50+ sucessful delids in other places (OCN, XS).
You tend to only see people say they've killed it, those that don't just get on with it (done 3 here no problems).
its great if you pull it off,you all must have thicker wallets than i
id happily straighten a bunch of bent cpu socket pins anyday than delid an ib chip
I would do anyones IB cpu for a small fee![]()
Thats where you went wrong brian, have some confidence mani loved every minute and if i got another hot chip i'd do it again.
Just the wrong tool used that's all. Still risky though, fiddly too.
