SkodaMart - Snodge has one single 670 not two yet.
No-one is doubting an i7 helps with two GPUs - LtMatt is talking about one GPU.
Yes Rusty is correct, sorry should have made it clearer.
Anyway my point was, i don't believe there is any bottleneck whatsoever with a single card and an 2500k in battlefield 3.
If someone can prove different, then please do so as id be interested to hear about it.
Hiya my rig's spec is in my sig I was wondering how I'd get on with two 670's overclocked on a 1440p monitor?![]()
I play bf3 in sli with gtx670 wf3 @ 1440p and 120hz I can say it run perfect on my system with everything on ultra. According to your spec it should fine.![]()
Your CPU is the next generation from mine which mean you have better physic score than mine.But you have an i7![]()
What games are you playing?![]()
The reason i7s run BF3 better with Multi GPUs is that they use hyperthreading. It does not matter if they are first, second or third generation or SB-E.
It is absolute rubbish that he should upgrade his CPU. Especially when it comes to BF3, there is no CPU botteneck. Even among budget CPU's! http://www.tomshardware.com/reviews/gaming-fx-pentium-apu-benchmark,3120-4.html
And hyper threading has NOTHING to do with gaming performance, in most cases the performance DROPS, it is merely for compiling, audio en video editing etc.. If you dont believe me, check this out: http://www.tomshardware.com/reviews/Intel-Core-i7-Nehalem,2057-12.html Same is applied for BF3.
When the resolution is this high, it doesnt matter if you replace your CPU with a monkey, the game will always be GPU bound. Ofc. exception are with CounterStrike 1.6, but with this rig were are talking about Crysis 1/2, BF3 etc..
Best thing to do is to get a GTX670 extra if your current card cant handle it, your CPU is FINE(Yes even with dual card setup) and people who think otherwise are ill-informed.
Moving onto Battlefield 3, we get a single-player test that puts a much stronger emphasis on graphics performance, though a capable CPU is much more necessary for a smooth multi-player experience.
we won't be able to draw any conclusions using Battlefield 3's campaign.
All test systems employ the fastest single-GPU graphics card available, AMD's Radeon HD 7970.
I dont recall mentioning that the OP replaced his CPU. Having said that BF3 is one of the few games that makes use of the extra cores/threads available on an i7. There are several people on these forums who have compared the i5 and i7 in the same rig and have found an improvement with multi GPUs. Have you tried this ?.
I found it interesting looking at the first link you provided, this is the first thing it said.
They were suggesting there was a difference, there isn't. What forum members experienced here is cognitive dissonance or just a new reinstall after upgrading there CPU. It's your word VS professional review. If you are an owner of an expensive and fast CPU, you will seek validation aka cognitive dissonance.(Not saying you do, but most people do)Bit too vague with the CPU types really, could have been a first gen i5 and second gen i7 which would see huge performance boosts.
*Facepalm* You have no idea what HyperThreading is for do you? It doesnt matter if it was from 1992. HyperThreading is NOT going to increase your performance in a gaming. This has to with internal working of HyperThreading and the overhead that it has. Native multicore can help by taking over tasks like Windows etc. in the background. NO game out there has true support for multicore for singlethreaded applications like games.The second link I belive was from 2008 and the only way BF3 would have been relivant is if they were running the system with a crystal ball in an expansion slot.![]()
Sorry lad but you are really off here.Yes the next step would be to look at adding another GTX 670. The only problem then would be that GPU usage in BF3 would probably drop. This is where adding an i7 to the system would increase GPU usage. Whether the increased usage is worth it is really up to the user.
Anandtech, Tom Hardware statistical approach vs cognitive dissonance on your side.....Actually you are - I upgraded from an i5 2500K/680 SLI combo to an i7/680 SLI combo. Same Windows install, same drivers... old CPU out, new CPU in... overclock applied.
GPU usage up from 80-85% in BF3 to 95-99% at 5760*1080 resolution. I didn't test fully at 1920*1080 but as JamesM reports - his minimums were higher with the i7.
If you're going to be so eccentric in your post you should at least ensure that you're right.
Check out the new link I put up in reaction to one of the poster before you.Wait, I thought we were talking about the differences between a 2500k and 2600k... that link doesn't bother with i7s
Also:
On top of that, you say:
When you can't back it up with data from your link which says:
Finally, as Rusty said, a few users on this forum have said they were CPU bottlenecked.
TL;DR: You're horribly wrong.
What forum members experienced here is positive feedback or just a new reinstall after upgrading there CPU.
I upgraded from an i5 2500K/680 SLI combo to an i7 3770K/680 SLI combo. Same Windows install, same drivers... old CPU out, new CPU in... overclock applied.
If not demanding a full 100% load with two cards, yes his GPU usage could go down as he has "horsepower" to spare. However adding a faster CPU will NOT lower GPU usage. GPU and CPU has completely different threads as if they dont bottleneck each other, there should be no difference.
