I'm not sure how much its worth having, a fast single SSD is fast enough on its own for me.
ill take a look at benchmarks and make a decision
everything else look ok to everyone? im trying to finalise the list today!
Thanks
Looks ok mate.
Look at this paste - http://www.overclockers.co.uk/showproduct.php?prodid=TH-000-GD&groupid=701&catid=27&subcat=
YOUR BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £269.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £209.99
1 x Gigabyte Z77X-UP4 TH Intel Z77 (Socket 1155) DDR3 Motherboard £167.99
1 x Corsair Obsidian 650D Gaming Midi Tower - Black £149.99
1 x Corsair Professional Series AX750 High Performance 750W Modular '80 Plus Gold' Power Supply (CMPSU-750AXUK) £139.99
1 x Corsair Professional Series Gold AX850/AX750/AX650 Individually Sleeved Modular Cable Kit - Black (CP-8920009) £52.99
2 x Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLT2CP4G3D1869DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** £49.99 (£99.98)
1 x XSPC RS240 120mm Radiator - Black £38.99
1 x EK Multioption Reservoir X2 250 Basic £33.98
2 x Bitspower Premium G1/4" Black Sparkle High Flow 7/16" ID (5/8" OD) Compression Fitting £8.95 (£17.90)
2 x Mayhems X1 UV Blue Premixed Watercooling Fluid 1L £7.99 (£15.98)
4 x Bitspower Premium G1/4" High Flow 7/16" Fitting - Black Sparkle Finish £3.98 (£15.92)
3 x XSPC 7/16" ID (16/11mm) High Flex Hose - Clear £2.99 (£8.97)
Total : £1,239.18 (includes shipping : £13.75).
Heres the basket plugin - http://forums.overclockers.co.uk/showthread.php?t=18371076
The PSU does come with all the cables needed, the extra ones I included (edited the above spec to make them Blue) are finished off nicely with individual braiding.
The board matched the colour scheme, was a bit cheaper, has a new type of power stage for the CPU and has Thundebolt as a further option.
The PSU was just to be able to add those fancy cables.
YOUR BASKET
1 x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £459.95
1 x Gigabyte X79-UP4 Intel X79 (Socket 2011) DDR3 Motherboard £209.99
1 x Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) £119.99
1 x Silverstone Strider Plus 750W Modular '80 Plus Silver' Power Supply (ST75F-P) £104.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (4X4GB) DDR3 PC3-17000C11 2133MHz Quad Channel kit (PV316G213C1QK) £99.95
1 x Gelid Solutions GC-Extreme Cutting Edge Thermal Compound (3.5g) £8.99
1 x Mayhems X1 UV Oil Black Premixed Watercooling Fluid 1L £7.99
2 x XSPC 7/16" ID (16/11mm) High Flex Hose - Clear £2.99 (£5.98)
Total : £1,291.12 (includes shipping : £13.75).
Well there isnt an equivalent IB CPU to the 3930K, but the Anandtech bench - http://www.anandtech.com/bench/Product/551?vs=523 - does seem to show the 3770k beating the 3820
Pretty much.
But also as you can see, you can have a 3930K for not much more and you arent really sacrificing on the board quality, I've been having a play and seem to have got 4.7GHz sorted.
http://forums.overclockers.co.uk/showpost.php?p=23073381&postcount=80
