Why an i3 rather an i5?
At the moment, I still run XP but I don't have the disks.
Did you buy the XP OS or did it come with your system?
YOUR BASKET
1 x Gigabyte HD 7770 OC 1024MB GDDR5 PCI-Express Graphics Card w/ FARCRY3 & 20% MOH WarFighter PC Games £99.95
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £89.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) £66.66
1 x Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £52.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £32.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £25.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £509.64 (includes shipping : £11.75).
You could use Win8 preview for a few months(90 days), until you can buy an OS.
http://msdn.microsoft.com/en-us/evalcenter/jj554510.aspx
Why i3 over i5?Also why a dedicated 7770 GPU? The integrated HD 4000 from the i5-3570K would handle Football Manager fine..
Because from his "brief" the i5K sounds a little overkill. I'm guessing he needs an optical drive too. Why are you using the Merc Beta? We have already discussed the Asguard Pro is a better budget case last night :/
You have to mix it up a little sometime! The Asgard isn't even in bloody stock still..The Merc Beta is still a nice case.
EDIT: I take it back, there are 8 left now.. No doubt they'll soon be gone again though..![]()
I don't think you've used one or you wouldn't seriously suggest it. People think it's fine "on paper" for the budget but there are much better alternatives.
Doesn't matter if it's out of stock. The Shinobi's go out of stock quickly too because they are popular. They can still be ordered and all the parts will be sent out once everything is in stock.
As you had already specced an i5 build, I did an AMD build to show the op there are other alternative builds to meet his needs and more. When he asked if the "Amd was better than the i5 for his needs", I told him an i3 would be better. Now, if he was doing a bit of video editing/rendering, then i would say i5. But, as hono has already mentioned, I think it is overkill and a waste of money, which could be better spent. But at least with the Z77 mobo, he has an upgrade path, if his needs change in the future.
I threw the 7770 in for better HD/BD playback and should he want play some other games, in the future.
So, the OP now has a choice of specs, all of which meet his requirements.
I think, if an OP is on a low budget, then he should get the best he can for money/performance. And not the first spec shoved in front of him. But at the end of the day, it`s the OP`s money and therefore his choice.
