E60 turn light issue.
28 Sep 2008
Britain
I wouldn't know how to explain this to Google so thought I'd ask here
My E60 has adaptive lights, they turn with the wheel. Nice. That works fine, but, what I have notices has stopped working is this:
Before, when I either indicated left or right or turned the wheel past a certain degree of turn, the inner bulb would light up depending on which way I was turning. This has stopped working. No check messages and no bulb warnings.
Anyone got any ideas?
I don't think you can turn them on or off they should always be on. Might be worth checking the bulbs maybe they arent monitored.
Actually, now that I think about it, there's lots of comments on various forums which suggests that they are monitored and throw a Cornering Light Failure if something goes wrong. Hmmmm......
Checked the bulbs, they are both fine :( Perhaps the recent visit to the dealer they uncoded it or something gay like that. Their dam probes!
Yeah I would think that it is a coding issue, especially if they have had a computer on it. Seems fairly regular that they muck something up when coding something else. Do your eyebrows still work out of interest?
Mine come back from the dealer without the gear up and down indicator deleted and something else I can't remember
I'd like the wing mirrors to fold when you lock the car, can this be done ?
as a retrofit sure, but surely if they fold from the factory they'll always fold (and you'll have the switch to fold them on the mirror module).
No, mirrors that fold in when you lock the car are a coded option - some do, some don't. You need to have it set in order to work.
Obviously you need folding mirrors too but that bit is obvious :p
