Who here has Metro 2033 and an FX-83## or FX-81##
Caporegime
17 Mar 2012
ARC-L1, Stanton System
And and AMD GPU, preferably similar to mine, or any will do.
I want to compare a Metro 2033 Game bench with Advanced Physx. :)
But it will still be inferior to an Nvidia setup seeing as Physx in Metro is an Nvidia implemented feature.
It also runs off the CPU if you don't have an Nvidia GPU.
That's with a 7970 and an 8150, which is running at 4.1Ghz with 4.4/4.6 turbo.
Looks like my results are pretty poor compared.
Yeah your MIN and Avg FPS are some 30% lower than mine.
That's really not good :(
Thanks for your contribution.
I'm still looking for some FX-83## results. :)
I dont see why you are so interested in this, I doubt it runs very well. Nvidia have made sure of that.
By the time there are cpu's fast enough to run physx, we will have even faster gpu's or no cpu's at all.
Actualy so far it runs perfectly fine, i run it in game and its smooth enough.
I'm interested to see is the FX-83## can deal with it better than mine, as a measure of its performance.
Thanks ^^^^ but its the CPU performance i'm interested in, your running Physx off your GTX 680 SLI, not the CPU :)
You might be interested in this http://forums.overclockers.co.uk/showthread.php?t=18451929
I can turn off Phsyx on the GPU and do another run.
Just went into the NV control panel and set Physx to CPU.
Performance as expected is terrible running Physx on the CPU.
Minimum frame rates well under 10 and averages in the 30's why would you want that.
FX8320 4.6Ghz Physx running on CPU
I don't know if that's any better than me or not.
I will repeat the CPU Physx test on an Intel PC later.
The FX83's IPC is too low to do the job properly i feel.
A comparison with your GPU's to that would be good :) but its impossible to compare Avg FPS when your running SLI GTX 680 against a 7870.
But your Min and Avg FPS are lower than mine, yet higher than X3T who is running an FX-8150 @ 4.1 / 4.4Ghz with a 7970 @ 1070 / 1400 which is not a to big gain from mine at 1200 / 1500
I don't think it matters too much what the GPU is with such a large bottleneck in the CPU.
I ran this test on my 8150 also and performance was lower than the 8320 at the same clock speed.
min frame rate was 6.87 and average 29 something.
didn't grab a screenshot and that CPU is not in the MB anymore.
The 8320 is a bit faster clock for clock than the older BD's such as the 8150
once the mrs gets up will run a bench with ur settings with physx on teh cpu then exactly teh same with it on gpu see what the difference is
