A week on, still not heard a thing!
-edit, just called MS, it's still in the warehouse waiting to be shipped![]()
We compared an ipad3 to a surface rt in work today. The screen on the ipad is nicer, it's higher res and shows, colours are more vibrant and seems to have more contrast as well. The surface screen looks a bit muted beside it.
Screen size though the surface is bigger and 16:9 so it gives much bigger viewable area in videos. Youtube will full screen on the surface while having to use safari on the ipad it always has the top bar so there's inches of difference.
VaporMg casing killed any hope of NFC. MS replied to queries about why it's not there with a statement saying it's absent as it doesn't work in the Surface - the casing kills the signal. They only get away with it with WiFi because they're using Memo antennas.
Would someone be able to post a screenshot of where/how you turn on device encryption on windows rt please?
cheers
Is this the same OS as the Microsoft tablets?
It's on permanently by default.
Can someone with a Surface try using Xbox music, turn off the screen and tell me what happens when the next song plays? On mine there's stuttering but this only seems to occur after a new track has started and only when streaming with the screen off as local files work fine.
Same happens on mine. Quick question is Xbox music free?
