And and AMD GPU, preferably similar to mine, or any will do.
I want to compare a Metro 2033 Game bench with Advanced Physx.![]()
But it will still be inferior to an Nvidia setup seeing as Physx in Metro is an Nvidia implemented feature.
, ill do cpu and gpu physx and put the graphs up
That's with a 7970 and an 8150, which is running at 4.1Ghz with 4.4/4.6 turbo.
Looks like my results are pretty poor compared.
I dont see why you are so interested in this, I doubt it runs very well. Nvidia have made sure of that.
By the time there are cpu's fast enough to run physx, we will have even faster gpu's or no cpu's at all.
Thanks ^^^^ but its the CPU performance i'm interested in, your running Physx off your GTX 680 SLI, not the CPU
You might be interested in this http://forums.overclockers.co.uk/showthread.php?t=18451929
I can turn off Phsyx on the GPU and do another run.
Just went into the NV control panel and set Physx to CPU.
Performance as expected is terrible running Physx on the CPU.
Minimum frame rates well under 10 and averages in the 30's why would you want that.
but its impossible to compare Avg FPS when your running SLI GTX 680 against a 7870.
