Man of Honour
- 13 Nov 2009
- Northampton
Got my DE89 on friday.
First impressions with Derby blades that came with it are excellent. No rash, irritation or razor burn that I normally experience, particularly on my neck. Ordered the popular blades pack from connaught shaving saturday so will start sampling some others when they arrive.
Feek, thats similar to how I later. I soak the brush in the sink for 30 secs the swirl it around the tub of TOBs 5 or 6 times then lather on my face. Brush holds enough like this for 3 passes.
You could also look at some soap that is specific for sensitive skin. I use the Proraso sensitive stuff and had no problems since. It could be technique too, don't be agressive just let the razor weight work it, remember every pass of the blade is removing layers of skin. Don't use alcohol based aftershaves either, use a decent post shave soothing balm and always moisturise!
