I keep seeing this around, seems legit
Had to kick the vcore up 0.01 but still a very acceptable max temp of 85C
[/QUOTE]
That's better, but you really want to be seeing 128 GFLOPS for that clock (80% of 32*5 GHz). 5800 MB is apparently not enough.
You might need to choose maximum memory, run it to suck up all the free memory, stop it, again at max, etc. until you're right at the memory limit. However, that might push it to paging off the HDD, which ruins the test. Getting it up to 7000 say would probably get you to 128 GFLOPS.
,shows wht a successful delid can achieve,wouldnt wanna put 1.4+ v through mine thoughHad to kick the vcore up 0.01 but still a very acceptable max temp of 85C
Unfortunately I did have a casualty with one of the e2140s. I was using a razor blade (the uber paper thing ones) and when i rocked it under the corner on one side I accidentally slipped and scored a chunk out of the PCB. I still have it to this day knocking about my toolbox and the house as have been meaning to make a keyring out of it or something. I would love to gt it working again. I might find it and open it back up and see if it is repairable, as talked about earlier in this thread by taping it up or something.
still good, i was hitting those temps @4.5 on air, anyone know the max volts for these chips under water?
so this is what Johnny 5 has been up to after escaping NOVA![]()
now running at 4.7Ghz @ 1.42v max temp 66c![]()
Intel don't give a recommended max for Ivybridge of 1.52V. It's a complete urban myth.
