- 9 Jan 2010
- Sunny Brizzol
Need to stop reading this thread, my 3770k keeps taunting me to remove its lid lol
I'll get some of the liquid metal (ultra probably though?) under the lid and maybe some gc extreme for the heat sink
Exactly what i have done, gotta watch the gc though, find it like treacle, got to treat it like a bottle of wine and twist before you pull away otherwise it goes everywhere!! Good job its non conductive
And the liquid metal really is like liquid metal, it runs!
VID isn't Vcore, all the 1.52V value is, is the biggest value the VID register can hold. It means nothing more than that. Intel DO NOT give a max recommended Vcore for either SB or IB. They do give one for SB-E - 1.40V I think off the top of my head and they might give one for IB-E but I've not checked. Any reference to max safe Vcore for IB or SB doesn't exist in the datasheets.Please provide evidence stating otherwise. I would like to see it.
All the Intel IB datasheets I have seen show a recommended max vcore of 1.52v
http://www.intel.com/content/www/us/en/processors/core/3rd-gen-core-desktop-vol-1-datasheet.html
Page 84-85 state max VID may be of 1.52 indicating that max vcore could be even higher, other sources state 1.55vcore
you will use wet and dry paper and not sandpaper wont you![]()
Frank M: we recommend to leave to default, but yes max recommended vcore is 1.52v, you can see the data sheet for more info specifications in this link: https://www-ssl.intel.com/content/www/us/en/processors/core/CoreTechnicalResources.html?
So the Intel rep points you towards the data sheet which is incorrect.
Sorry, but when you say things like that you can understand why people find it hard to believe anything you say. So far the only misinformation being given is from you, and I have no reason to believe you over an Intel Engineer.
As jokester has explained, the maximum VID a chip could leave the factory with is 1.52, because as some point in the design they had to specify the format for saving the VID to the chip and settled on 0.7 to 1.52 or whatever. I'd bet a lot of money though that the highest VID they actually end up putting in to the chips is way less than that (say 1.15, 1.2, something like that).
The stock clock speed and voltage is chosen to last a long time and have a vanishingly low error rate. Increase the volts = decrease the life of the product. There's no going around that.
As for a "max safe voltage", nobody can answer that, it probably depends on how long you want to keep the chip. Next time, a better question for an intel engineer might be "if I want to run my chip for 4 years 24/7, what's the max voltage I should use to have a 95% chance of not killing it?".
I've referenced the specific section of the spec to show that the 1.52V figure is not the max safe Vcore. Anyone can look at the datasheet and confirm that for themselves. As a comparison, here's the applicable section for the SB-E max safe Vcore value:-Sorry, but when you say things like that you can understand why people find it hard to believe anything you say. So far the only misinformation being given is from you, and I have no reason to believe you over an Intel Engineer.
