- 20 Jul 2009
- Midlands
Who knows! BUT reviews are coming
Take a look below at the new Sound Blaster Z by Creative. Using similar technology to the Recon3D but with better caps and other key components the Sound Blaster Z is on paper perfect! However, only your ears can be the true judge and from what short tests have shown this new sound card is very special and perfect for those looking for an alternative to the exquisite yet ageing Xonar D2X.
Take a look below....
Creative Sound Blaster Z High Performance Gaming Sound Card - Retail (70SB150000001) @ £79.99 inc VAT
If you’re not communicating you’re not winning!
Part of the ultra high-performance Z-Series of Sound Blaster® PCI-Express sound cards, the Sound Blaster Z is an ideal all-around gaming and entertainment solution that incorporates all the hardware and software features of the Sound Blaster Zx card and comes with an external high-quality beam-forming dual-microphone array.
When used with CrystalVoice™ the bundled Sound Blaster beam forming microphone creates an acoustic zone and suppresses noise outside it, enabling you to be heard by your teammates with amazing clarity even in noisy environments.
- Output Level (Full Scale): Front Channel Out : 2Vrms, Headphone (33 ohms): 1.3Vrms, Headphone (600 ohms): 2Vrms;
- Maximum DAC Resolution: Front Channel Out : 24-bit, 192kHz, Headphone (33 ohms): 24-bit, 96kHz, Headphone (600 ohms): 24-bit,
96kHz;
- SNR (20kHz Low-pass filter, A-Wgt), @ 24-bit, 96kHz: Front Channel Out : 116dB, Headphone (33 ohms): >105dB, Headphone (600
ohms): >105dB;
- Frequency Response @ 96kHz: Front Channel Out : 10Hz to 45kHz, Rear Channel Out : 15Hz to 45kHz, Center Out : 10Hz to 45kHz,
Headphone (33 ohms): 10Hz to 45kHz;
- Frequency Response @ 192kHz(Stereo only): Front Channel Out : 10Hz to 88kHz;
- Supported Output: Stereo/2.1 Speakers, 5.1 Speakers, Headphones;
- Headphone: 1 x Amplified 1/8" mini jack;
- Speaker Out: 3 x 1/8" mini jacks;
- Optical Out: TOSLINK;
- Optical In: TOSLINK;
- Line In / Microphone In: Shared 1/8" mini jack;
- Warranty: 2 Years Manufacturers Warranty;
Only £79.99 inc VAT.
ORDER NOW
96kHz;
ohms): >105dB;
ORDER NOW
