Replacing H80
21 Oct 2004
Wales
Just thought I would hit up the forums for a little help. My H80 has recently begun to emit a low volume high pitch whine which seems to be coming from the pump itself. So I have decided to replace it in 2 weeks time with something better but the problem is I am having some trouble deciding what to replace it with.
The reason I bought the H80 was because I was looking for a decent and very quiet cooler and my system has done well in that regard so quietness is definitely top on my list of priorities for a new cooler. My system is overclocked but not too heavily at 4.4Ghz @ 1.264v and I do not really need anymore than that right now. Under IntelBurnTest and Prime95 the highest temps I have seen is 68oc so its running pretty good if you ask me.
I have a Fractal Design R2 *Arctic White* so I do have a good amount of room for a CPU cooler, my H80 by the way is fitted with 2 x 1850GT's running at 1250rpm so anything under that would be fantastic!
They come with a 5 year warranty if that helps.
Most of the top twin towers will fit in your case.. RAM height and GPU clearance permitting.
K2 . =. . 140x128x158mm 146x154x160mm w/fans (W x D x H looking from front of case with motherboard laying flat)
D14 =. . 140x130x160mm 140x158x160mm w/fans
TC14 =. 140x134x160mm 140x159x171mm w/fans; fans can be mounted lower. (have R2 with TC14 w/fans @ 165mm)
SA . = . 147x123x160mm 151x149x160mm w/Fans
SA-SBE = 155x105x164mm 170x130x170mm w/fans; 150mm fan is too tall
SA-SBE Extreme 155x105x164mm 155x130x165mm w/fans Reason it's smaller is 140mm fan vs 150mm fan.
HE01 =. 140x119c160mm 140x38mm fan in middle
Don't rule out single towers. Some are as good as twins and many are only a couple degrees away. I do know the True Spirit 140 will not fit. :(
RMA it to corsair, im sending mine once UPS email me, they are replacing mine with the h80i. Its worth ringing and asking them, im on my 5th h80!
5th replacement :eek:
Some people are very slow learners :p :D
Edit: Keep us posted on how it all ends up. Corsair definitely isn't making any money off of the H80 you bought. ;)
